scarecrow
Outstanding in his field
This could be a good thread to write things down in and link from a helpful information page - I've moved posts from from the original thread to make them easier to refer to later on.
But I'm confused. I like "Positive gives positive penetration".
For thinner metal that might suggest putting the arc rod holder into the positive terminal (DCEP) would end up with more holes and blow through.
For thicker metal puttting it into the negative terminal (DCEN) might not give the penetration you might have wanted.
I can imagine it's even more complicated than that. I understand that if the rod is positive it will get 2/3 of the heat of the whole weld. But if that extra heat is transferred to the metal by way of a stronger arc the thing you were trying to weld will end up hotter than if you'd made the rod negative.
Is that a reasonable summary or am I still confused?
Okay I put my hand up I was wrong
gave it a try on some 3mm Box DCEP just burnt holds
DCEN putdown a nice weld
DC current or direct current only flows one way that is from positive to negative' I think. so I presume the difference is where the heat is generated in the arc whether it's on + OR - side of the arc
