Matchless
I started with nothing, still have most of it left
- Essex UK
I have repaired the oil union hole in Matchless single engines by techno welding in a brass union fitting, techno / Lumi weld sticks to brass but not to steel, you can form a crude thread by techno welding around a steel stud, when it cools and you remove the stud you have a thread! I have also repaired a casting blow hole deep inside a BMW cylinder head inlet port that would have been impossible using tig, mig or much else, it needed heating in a big oven to get up to temp. and careful slow cooling but it worked, main problem with even small casting repairs is getting enough heat into the piece.
