providing the board supply the earth there's no need for rcd protection on your compressor just an mcb
as u say it depends on a lot of things. being in a garage though and its a compressor its hardly likely for the cable to be buried in a stud wallAs long as they don't have MCG printed on them you'll be ok....
Depends on lots of things now like is it wired in twin and earth concealed in a wall at a depth of less then 50mm or being run in a metal stud wall, that still requires a 30ma RCBO. 3rd amendment. If it's a new installation.
more like clipped direct to the wall or wired using conduit or mini trunkingHope it works out, had a nose on EBay but couldn't find it.I won the compressor, I got it for £110 on ebay because it was badly described and listed as spares or repair. The garage selling it aren't sure whats up but reckon they were told it's a minor fault. Will see once I've picked it up. It's a Clarke 18 CFM 200 litre, 4 HP.
Ok I will see of I can adjust it down to 145 psi.the pressure switches are adjustable for whatever u set it to. a cheapo 12 quid one will fit I use one on mine but have wired it through a contactor so that the switch contacts just operate the coil not the main motor load https://www.ebay.co.uk/sch/i.html?_...1313&_nkw=compressor+pressure+switch&_sacat=0
Have a look at http://www.pipefittingsdirect.co.uk/contents/en-uk/BSP Identification1.pdfSo I just need to plumb in the unloaded. I don't know how to measure imperial fittings though maybe need to get an imperial thread gauge.
Thanks but I also need to identify the TPI don't I? I looked on ebay, all the imperial thread guages are 55 degree Whitworth. Are these ok for meauring BSP, UNF, NF, NPT, and other imperial threads? I know very little about imperial threads.... my age shows... And how do I tell which of the imperial systems (BSP, UNF, NPT, Whitworth etc) it's using?Have a look at http://www.pipefittingsdirect.co.uk/contents/en-uk/BSP Identification1.pdf
This gives the size in mm you are looking for.
Is the unloader pipe still connected to the non-return valve? Is it a copper or a plastic unloader pipe? If it's copper it will be an olive fitting, if plastic it'll be a push-fit. You could very well have a push-fit on the switch and a copper pipe on the machine. Have you got the original switch?
