What spooked me was they stressed it was a t peice splitter not a regualtor. I would hate to wait a month for it and then find the pressure adjuster was just cosmetic without function. I have been comparing the two and they do differ in construction, i appreciate the input but prefer to play safe with a uk supplier so i can resolve any issues if required by a phone call.They all come from China , just shows what mark up goes on them![]()
I have the same one with the same problem, 2hp 50l? Let me know how you get on as I never really used it and just bought a replacement as i had trouble removing the manifold from the tank, turned a couple of times then couldn't loosen it anymore for some reason? I use the oil free for shooting powder and as i replaced it i would like to add it to my main compressor for some added capacity when blasting.
mike
No problemWhat spooked me was they stressed it was a t peice splitter not a regualtor. I would hate to wait a month for it and then find the pressure adjuster was just cosmetic without function. I have been comparing the two and they do differ in construction, i appreciate the input but prefer to play safe with a uk supplier so i can resolve any issues if required by a phone call.
Its such a relief to me that a repair is in sight. Fingers crossed all the fittings are the same as mine.
Read through this link Mike, it explains how to remove the T peice.
http://www.mig-welding.co.uk/forum/threads/t-piece-needed-for-air-compressor.16630/
i just found the motor cuts at just a little over 120 psi, so i guess the cutoff is within the switch housing and nothing to do with the T peice. I would be ecstatic rather than just a happy man tonight if i had managed to get that brass union off but even though its leaking i think its best left alone. The compressor is perfectly usable again, ive even found the T peice on ebay now cheaper...£ 5.99 delivered should anyone else need one ! It would seem the large red adjuster seems to do bugger all and is for looks only, the original used to alter the left gauge and output on that connector i'm pretty sure.
