up to the job of what , cutting 5mm , it will , a nine inch with laser discs will cut 5mm no prob , if you go slowly and dont let the blade flex as they tend to try to do , if you put a guide line on it with a 4 1/2 inch first it will be a lot easier if your not comfy with a 9 inch .. secret is to let the machine do the utting and not be tempted to put pressure on the blade , as they wear out very quickly and tend to wander if you do that ,, or you could clamp or tack a bit of angle on and cut down it using the edge to keep you straight.The compressor is too big to move. Its also wired directly into a 40amp supply.
I think i will go for a thicker top, say 5mm.
Ill get a quote for some box too.
I need to be conviced that angle wouldnt be up to the job though, im not bothered about the aesthetics.
I meant angle steel vs box
First One is from a great Vietnamese channeli rather like these
welding table and plasma table
you will be grand ,, take a while drawing it all oyt before you start though ,, things like getting your knees under the bench if you sit at it , and heights for a vise to be comfy if you beat things , or spend more time with a file than a hammer ,,,I have a quote for 18m of 40x40x5mm angle, 1000x2000x4mm sheet. It also includes 18m of 20x20x3mm angle and 1000x2000x1.2mm sheet for another project.
Delivered is £203.
I think im going with this as its definitely beefy enough for automotive work.
The other project is some overhead racking for the same garage.
Hoping my begginer skills and a tecarc 181 will be upbto the job.
Ooh, I do like a bit of Galv!bugger still not got the two 90s in View attachment 252903
there you go ,,, Now if you want more i can go look on my computer .
