Screwdriver
oops wrong thread...
The main event is this bad boy.
Six foot long, four bends.
Doesn't sound too bad until you have to manoeuvre it around a cramped workshop to get at both ends.
And after all that, it still looks flat!
One 30˚ bend and one 60˚
The marks line up ok
Bent (much more sensible job for the flypress).
The bends are so strong it was hardly worth welding but I put the MIG in there so...
All done.
Just need to lift it above my head and hold it level while I bang in a couple of screws.
Should have been a video, sorry chaps but I got it up and installed.
It looks exactly how I wanted it to look. Very happy. Need to drill out some vent holes for minor extraction duties. It's not a chimney per se, just want to waft away any nasties from the propane forge. Might help keep the place cool too but I was burning off the paint from some chopped up car springs and thats not healthy even with the doors open.
Fume hoods are worthwhile investments! Even for things like bodyfiller which tots your lungs. I’ve got a tin at home made in Poland, one of the (many) warnings on it is to keep it away from pregnant women!
I made a "fume hood" without even knowing it! How about that![]()
Because it blows everything inwards.
The last thing you want to do is pressurise your workplace. Normall industrial convention is to have your room under a slight negative pressure so the extracted air goes where you want. As others have pointed out fitting a chimney is the best way forward. Any heat and emission from your furnace will be thermally buoyant and will want to rise. With a correctly fitted chimney. The buoyant air will be entrained into your capture hood and removed away from the work area. If done correctly you won’t need to spend any money on electricity to run a fan. This is a tried and tested method of providing local exhaust ventilation
I appreciate that and I could fit a system which sucks air out into the makeshift fume hood but all I need right now is a reasonable waft of fresh air as and when required. I can always throw the double doors open. Unlike an industrial environment, there's no one working in there all day so as long as there is some ventilation, I'm happy to wait in the event of excess smoke/chemical fumes.
I can rig up a (makeshift) vent duct from some 110mm soil pipe I nabbed off a neighbour. My theory is that gas in an enclosed space is a bit "stringy". Pull lightly on one end and if there's not too much drag, the rest should follow. Since the fumes I am interested in removing are hot, they should already be happy to hang around the ceiling and dive up the hood skirt. I reckon they just need a teensy bit of encouragement.
Have an experiment and see how you get on, but if I’m correct in understanding what you de# rice sounds like the beginnings of a push pull ventilation system. These are one of the most complex types of system to set up. Always get lots of problems with eddy currents disrupting airflow. One possible solution is to install ventilation grills in your door. With doors closed it should create air movement in the right direction, ie up and into your hood
all them holes in the wall next you will be complaining its too cold to work in there in the winter![]()
put it this way i suspect it will fail
rooms are always negative not positive
for start off too many holes 2 holes is enough as others wont get air from it will just pull from the first
if your intent is still to use use a side blower only then use it to pull air out of the room by using a venturi
easiest method put an 1" square tube inside a 2" tube or round tube the air being blown past the 1" will suck air out of the room
the fan is your problem i suspect its a side ways blow out with it if it is all you need to do is put fins on it to make it directional
