Kent
- Bowland, Lanacshire,UK
Initial thorts are to get a pice of 80mm plate burnt out once I settle on design/dimensions. 40mm shafts mounted in 6008 bearings. But now you have me thinking about moveing the bottom rolls so all could change.
Your drive wheel is the top one light knurl and hardened to 54 Rockwell. This moves up down
The lower wheels are not knurled and interchangeable for section shapes. These move in and out. In for easy bar bent tight and out for bigger bar bent lightly or more stages. Easy enough with slots
Springs to tension and lead screws to adjust
Rigidity of the frame should be overkill
Just my thoughts and observations and advice sought gradually
