Jim Davey
R H Davey Welding Supplies Ltd
- Southampton
No catch, if it gets warm the fan comes on, if it cools down fan goes off. The only catch is that you need to find the part of the machine that gets hottest first. In an inverter it's the heatsink. In a transformer machine it's the centre of the tranny that usually gets hottest (it will retain heat for longer too because of the tightly packed windings and iron core retaining heat well) so if fan as needed is required then the temp switch is inserted into the inner part of the windings when the transformer is made. Rectifiers due to their aluminium plate design shed heat quickly so of you mount the temp switch on the rectifier it can get hot a lot slower than the tranny will, then rapidly cool after you stop leaving the transformer still roasting away.
You need to be sure to put the sensor in the right place and make sure it has good thermal contact with the parts you want kept cool.
No good having the switch right in the airflow but not having a good thermal connection to a heatsink as the switch itself will switch off leaving the heatsink still hot, that's why you use the heatsink compound.
