Stripping paint from car panels
How to strip paint from car panels? The only way that's not a pain is when someone else does it, and then it's expensive. I'd considered chemical dipping, but decided I wouldn't be able to repaint the hidden areas the chemical dip removed. There's more discussion about the alternatives at the bottom of the page. But first the cool new way I found of doing the job. |
What are the other alternatives for stripping paint?
I considered a number of alternatives for this project. Also there are other things to strip like underseal for which the strip and clean discs would be rubbish. Here are my thoughts on various ways of stripping:
Sand /Media blasting
Most people that do sand blasting use great big high pressure rigs so an even greater chance of bending panels. Anyone looking at blasting thin metal seems to use media blasting instead using things like walnut shells or plastic beads.
Having said that, low pressure shot blasting using grit works really well on thin panels, but is slow. See DIY sandblasting.
Chemical dipping (acid dipping)
I had planned to have the whole car dipped. But dipping removes all paint even from inside inaccessible box sections. Most cars built after 1980 will have been paint dipped during manufacture, and it's a shame to remove all the paint the manufacturer has added to all those inaccessible box sections (especially as it would be impossible to get new paint back in). Others have raised concerns that it's difficult to wash out all the acid after dipping, and acid in my seams was the last thing I wanted.
Some companies offer an e-coating (primer dipping) service after chemical dipping, but the price for stripping the Renault and having it e-coated would be £3,000. That's more than the car will be worth.
Wire brushes
Wire brushes work well when used with paint stripper, though there's a lot of cleaning up of the residue to do afterwards, and finishing off with wire wool and paint stripper. The wire brush attachment works well for plastic underseal or anti-stone chip though. Especially when the plastic stuff has been softened using a heat gun. It's a messy job though, and I tend to alternate between the wire brush and an old table knife (both used with the heat gun) for that sort of work.
A hand held wire brush is handy for using with paint stripper if there is a lot of paint in a fiddly area. Though again that needs to be finished off with wire wool.
Sanding discs
More abrasive than the strip disc and prone to clogging. Good for finishing welds though.
Wire wool
I use stainless steel wire wool. It's available in big rolls from exhaust suppliers such as Millner Off Road. Be careful of the stuff though. I used to tear wire wool from the roll before a single strand decided to slice through my finger rather than tear off. Now I use scissors to cut it from the roll. In conjunction with paint stripper it's a great way of removing thin paint, or the remainder from tricky spots after some other paint removal process.
Heat gun
A heat gun used with a scraper is ideal for removing underseal and plastic coatings, but might distort flat exterior panels.
Paint stripper
This features in a lot of the methods above. It can be used with a scraper or table knife, but the methods above are all quicker. Be sure you get a decent brand though. The unbranded or store branded paint strippers are a lot less effective. Wear rubber gloves and maybe a mask too - makes me feel unwell when the stuff gets into my system.
