ajlelectronics
- Gloucester, England
In particular, I believe that facial hair can prevent the seal working on a non air fed mask.
A pro would make sure every safety aspect has been covered imo.
If their painting in a proper booth then the fumes are being extracted through the ventilation system.The painter at work doesn't use an air fed mask when he's in the booth just a replaceable filter mask.
The HSE rules require an air fed mask not because you can't make a filter that is good enough but because of the difficulties in ensuring you always get a good seal between the mask and the face.
With an air fed mask there is no requirement for such a seal. So it is more idiot proof.
I thought there was NO filter available to filter isocynates, hence the reason for air fed?
No, it's particles of paint cloud that need filtering, relatively large. Airfed exists because it's safer & more reliable, than chuckaways.
Compared to the cost of a pro respray, airfed is notalot of £s, especially a few jobs down the line.
Threads like this can go on forever. Bottom line, everyone has to make the choice whether to risk a chuckaway or not.
Hi Anto,
That might help answer your question.http://www.srsafety.com/upl/files/5995.pdf
I also contacted the manufactor which told me that in the UK the gov recommend an air feed mask. I don't know about Ireland.
He also told that in other european country it might not be mandatory depending on the country.
thats not the case its the isocyanates that are the issue here other paints are fine to use with carbon filter masks
