I think that in inexperienced hands the 6013 (or some 6013s) are easier to use because you can angle them so the flux is touching the workpiece. You really should keep a gap with a 7018 and it aint easy for a beginner.
From my point of view, lo-hy used properly seems like a total mission to be avoided unless big bucks are involved, in which case the handling procedures are lost in the noise. You just accept that there's a discipline you are working under.
Moderately lo-hy, fairly low-hy and chuck 'em in the airing cupboard and pull 'em out for a superior result are not what I thought lo-hys were about.
must been missing something whilst welding as i never bother watching/studying the weld pool (except perhaps a bit when going vertical up) as its covered in slag anyway. its all about the feel/rhythmI do remember the weld pool was easier to see (weld pool = yellow, slag = orange).
If you only need a couple of rods downhand or horizontal then 6013s are fine, but if you have a few positional welds, using lo-his makes life much, much easier. They should be dried to spec as many lo-hi's just don't work well if damp (apart from the porous/brittle welds), but it's not all about weld strength as the fast freeze characteristics are just a bit useful.![]()
You and me both know however that rods with the same AWS classification vary in characteristic's hugely....
even a single mfr may have 20 6013s and the same in 7018s depending on use, and most will make a 6013 with a fast freeze characteristic, worth looking past the AWS no, as I think T/A touched on.....
Is it true that the main difference between 7016s and 7018s is usually the thickness of the flux coat and the the flux is the same, they both usually have iron powder?
Hi every body,
God so much info..... thankyou everybody. Going back to my opening post...... Could somebody recomend a good 7018 rod for me to try(make,type, ease of use etc ), considering I have no experiance using this type of rod and using my pick-hill 210 amp oil cooled welder ? Once again thanks for all of the help............
Hi ,
Could somebody post pics of 7016 & 7018 runs so I can see the weld bead finish ? Just like to add ,great support for somebody wanting to learn more ! Many thanks, Med.
