Bede
Gob*****
- Stoke on Trent
Been dabbling around with setting and tests on 40mm plate with my 320 amp mig. Ran a few runs initially with 1.0mm wire then stepped upto 1.2 and the difference is quite noticable.
The first couple of pics are of multi-runs at just shy of 300 amps on 1.0mm mig wire. Nowhere near enough penetration. The next couple are of 1.0mm wire at 320 amps, wire feed at about 14 m/min - penetrates well into the smaller block of 40mm but just sits on the wider plate. Still not enough juice.
The final couple of pics are of 40mm, root one side, root and two caps on the other, at 320 amps with 1.2mm wire fed at 13 m/min. Acceptable levels of penetration but to be honest I'd rather a touch deeper.
Anyway, just thought I'd stick up some examples. I'll also show a couple of roots from the lower settings on 1.0mm wire. Upon imnspection they look fine, until you etch them and discover inadequate penetration.
