Kayos
Gone......
- Yorkshire
@Kayos you are correct in stating fabric first... you need to know the total heat loss to match the minimum heat input. The type of building and its construction then becomes irrelevant, but the costs can be eye watering.
@Welderpaul i suspect your underlying issue is related to the above. Uk insulation and leakage standards are still a bit (lot) pants and still fall well short of passive/scandi insulation standards. If your system was specified for a passive house (which at 6kw seems very likely) but you don't meet or exceed that criteria then it's never going to work when it gets cold.
I also suspect the "standard information" for system capacity is based in an unrealistic ideal perfect universal building model with no basis in the real world. When "everybody" says its right but it doesn't work and the "experts " want lots of cash to make it work I find myself catching the strong smell of manure being thickly applied to cover over the cracks.
We don't use standard information, we do extensive surveys and build a digital twin of the building, this enables us to model and simulate all different options
The fact is that it's often cheaper to have slightly higher energy costs than spend the huge upfront costs on fabric upgrades
