More Amps
- Scottish Borders
Ice can be lethal!Jesus
I think I’d have just wet the bed and rolled over to find a dry bit!!
Oil, package system boilers outside in a box……then your not tied into an expensive tank contract.I think i'll bite the bullet this year and rip out the air source and fit a combi running off propane with an underground tank.
The quotes to make good the ASHP system are huge, and i'm not convinced throwing more money at it will fully resolve.
Accredited or not if the installation is not fit for purpose it has to be worth bouncing that ball to see where it lands.Was it fitted by an MCS installer? If so I'd be into them for money
Thats really bloomin annoying!The quotes to make good the ASHP system are huge, and i'm not convinced throwing more money at it will fully resolve.
Bob
That looks lovely set against that sandstone wall...Pricey but another option
Hybrid Home Heating Systems - Air Source Heat Pumps Hybrid Solutions, Manufacturer & Supply Grant UK
The Grant Hybrid range includes the VortexAir heat heat pump/oil boiler hybrid and the EvoLink Hybrid System Hub for combining a heat pump with an existing fossil fuel boiler.www.grantuk.com
Mmmmmmm yes, really needs to be in a shed so you cant see it, when it was suggested I went for this set up, it did make me wonder if the makers knew the heat pumps can be a bit “ the emperor has no clothes on”.That looks lovely set against that sandstone wall...
Quite unbelievable my post appears to have been deleted as I broached an unpalatable truth.
ASHP work fine if the building is fit for it. I know a number of folk who've built their own places and exceeded passive house standards in some cases. Paul said his place is well insulated and to current regs. Unfortunately mass builders don't necessarily understand the importance of getting insulation and airtightness right and results are often fudged for sign off. The folk I know are anal about it. The result is an ASHP that works and really well. Some even use theirs for slab cooling in summer.
This post (as you now state) involves a new build, yet you continue with the nonsense
Rather than it get personal and be as rude as you have been to me I'm going to ignore you.
@Kayos , can an air source be tied in with ground source as in the bore holes you were involved with? Just wondering if a combination of the two would be a viable solution.
Bob
im sorry to say a sealed house award means jack all and i see it so oftenFabric first is important, but understanding system design, building use and heat pumps is much more important To be fair, the design alone probably costs 10 X that of a domestic install, but yeah, fabric first is the only approach
I have installed and I am currently planning to install heat pumps in buildings that are scheduled ancient monuments, the ones that need the secretary of state's approval to work in
We categorically cannot alter the fabric, yet the heat pumps work exactly as designed, providing the correct level of comfort and hot water, while removing the need for fossil fuels
