So if you did not have one could you put them in the order you would buy them?You can get Ender 3s for under £150, sometimes they have ones hat have been returned and checked over for under £120 (which is what I purchased). Then add £10-£15 for a glass bed. The Ender 3 was my first machine and the CR10 second (then I was given the others). Some of the Anycubic printers also have good reviews. If I need speed or highest quality I will use the delta (its also fun to watch but will drive you to despair trying to keep it working) Then if it fits, I will print on the Ender 3 and it is only if I need the print volume (or need to print a few parts at once using multiple machines) I will use the CR10 units.
One thing I forgot to say, the CR10 and CR10 mini require a lot less assembly work (an Ender 3 will take 2 or 3 hours to build, the CR10 is a few minutes)
I just hope that I can correctly identify the pin outs at each plug or socket end for me to make the converter myself .
And of course find a male SD card plug that can be soldered on to
