Changed my mind on how I was going to do this and ended up a bit compromised.
Originally I was going to drill and re-tap the base but then changed my mind and re-used the original holes. Trouble is though that these then exited in the raised "ring" section. So I had to counterbore them but as the milling machine is still in bits I and I don't have a suitable counterbore tool I had to do them using an end mill in the pillar drill. Now I'm fully aware that milling in a pillar drill is a big no-no as there is no retention of the chuck (beyond the morse taper) and it doesn't have the sideways stiffness to do it. I figured however that as I was "plunge milling" and hence no sideways action it would be ok. It wasn't. There was enough sideways deflection that it vibrated horribly and then dropped the chuck out. Managed it but ended up having to take it really really slow.
I also lined the oil port up nicely between two of the mounting bolts but didn't consider how it aligned the nut! I mean it doesn't matter but it would look neater if the flats were perpendicular to *one* of the axis (or even at 45°!)
It's functional however and not so bad that I feel I have to redo it!
