That component was originally named "TS1" - throttle solenoid? In the diagram from the manual that I posted it is called "CR1" and the parts list describes it as "Relay, enclosed, 12v DC, single-pole, double-throw". However, the circuit diagram does not show a relay coil, there is no wiring for any contacts, and the "relay" has no item number in the parts diagrams.
I think/assume the contacts are the 2 parallel lines that look confusing like a capacitor symbol in the high-side of TS1 path.
While I sit here in the back ground letting you electrical or electronic guys do your thing,
Typical the image from my amazon purchase list has the end cap covering the terminals, wires 40 & 41 connect to the terminal's, when I check from the positive terminal to the body of the solenoid it give a continuity reading, also the buzzer goes off, the same when I check the negative side, this is with the wires disconnected, just the bare unit bolted in place.Well, that doesn't sound right. I wouldn't expect either of the 2 terminals to be connected to chassis ground given the circuit diagram we've been discussing so either the solenoid is faulty or the wrong part. Or there's expected to be some insulating material between the case and the chassis (but I find that unlikely).
Sorry... but can you clarify your 1st statement and add the diagram as an attachment? I used to do lots of this for a living. Can't promise anything though.I have a diesel welder, its a BOC transweld DELL-200 its a miller in different clothes, the machine wont come off high idle unless the power / weld switch is on power setting as soon as its in weld mode the revs pic up regardless where the auto idle switch is set too, on or off,
Do you have a diagram of idle control board?
Untitled by chrismac2012, on Flickr
Untitled by chrismac2012, on FlickrYes correct, so looking like a possible fault with the solenoid, my next planned move I think is to remove the solenoid and test across pins, then remove negative wire and fix to the body and see what happens, the strange thing is this was all working correctly after my initial repair to the board.based on what you said the other day about there being continuity between the solenoid pins and the chassis when no wires were connected to the solenoid - I'm convinced this is just grounding itself through the metal mounting hardware. I assume the battery negative lead goes directly to the chassis.
Thats what I did insulated the solenoid from the chassis, no change, even removing the negative wire while in weld mode did not release the solenoid, I assume this could be partly to do with the pull and hold type of solenoid, starting to think this thread is not going to have the outcome I had hoped, very thankful for the help to date though.Can you not just electrically isolate it from the chassis by making an insulating mounting?
Or just to prove the theory, remove solenoid entirely but leave the 2 wires connected to it and observe whether it behaves as expected?
