well spotted, unfortunately its just my poor photography angle and a leg from the heat sink.Just an observation but that orange capacitor C54 on the circuit board looks like it has a big chunk out of it. Maybe nothing.
Think it's just punctuation....that's blurring me. Got PDF now ...eyesight issues need to zoom in.Hi, there should be diagrams visible in previous posts, if you can not see them then in this manual
https://www.millerwelds.com/files/owners-manuals/O412G_MIL.pdf,
Can you open that link?
what would you like clarified on in my first statement.
Thanks
"I have a diesel welder, its a BOC transweld DELL-200 its a miller in different clothes, the machine wont come off high idle unless the power / weld switch is on power setting.
As soon as its in weld mode the revs pic up regardless where the auto idle switch is set too, on or off,"
Yes correct thanksThink it's just punctuation....that's blurring me. Got PDF now ...eyesight issues need to zoom in.
Off in caravan to Devon will mull it over whilst away. Diesel welder/generator and problem is only in weld mode?
I'm confused then. My understanding of the solenoid you have is that if you connect the 2 terminals to a 12V battery it will pull in. When you remove the negative terminal wire, it will spring return to its resting position. Because it's a spring return type, it's going to need to have a complete circuit + and - to keep it held in against the spring, unless it's mechanically sticking. But, we know it isn't mechanically sticking because it releases when cutting the positive to it using the W/P switch.
1. How did you insulate it when you tested and did you electrically prove it was isolated from the chassis with a meter? You see, I'm wondering what's underneath that black boot - maybe a metal plunger pin that may still have provided an electrical path to ground via whatever levers it's moving?
2. Did you try physically removing the solenoid from the engine but leaving the 2 wires connected, laying it on the concrete, then seeing how it behaves? I'm curious whether that works as expected.
3. Also if you entirely remove and disconnect the solenoid you could check it's behaviour just by connecting it to a battery, make sure it pulls and releases like we are all assuming.
4. And for a bonus experiment, take the 2 wires off the solenoid and connect them to a 12 lamp, use that to indicate what the control circuits are doing when in weld mode.
That sounds like it working as expected? To be really clear though - does it hold for the entire time the battery remains connected?Battery connected, solenoid pulls and releases when connections made,
These are expected. Auto mode does not need to pull in for more revs if not welding.lying on ground weld and auto mode selected, nothing happens
lying on ground weld and auto off selected, solenoid pulls
lamp test showed the same,
Then I had a thought, set in weld mode auto idle and struck an arc, revs pick up (read on though as more test carried out)
weld in auto mode, solenoid pulls but drops off after approx 5 sec
weld with auto off, solenoid pulls on for 5 secs and off for approx 18 secs, repeats this cycle.
Weld + auto-off has the solenoid across the battery via those 2 switches.
Before I dive into the rest, can you clarify where the solenoid was and its insulation status for the following comments:
It's my understanding that the solenoid has an internal switch that disconnects the powerful coil once it's been pulled in and just leaves the hold coil energised.Yes it holds for as long as I dare hold it, not wanting to roast it, I believe there is a lower hold current?
That, I think, is to be expected as you're now measuring the path back down the negative wire through the auto switch to ground (and various other paths too). The important point here is that with the insulation in place, we get to choose when that negative solenoid terminal get connected to ground and that'll be eitherSorry, I should have been clearer, solenoid refitted, insulated as much as possible as there is some continuity once the wires are connected giving a reading.
lying on ground with weld and auto off selected, solenoid pulls
To try and diagnose one thing at a time, I'd take the idle board out of the picture by removing the wires from C. That way the only thing that provides that path to ground is via the auto switch.
I can't tell from the photo, but I assume the blue wire on C comes from the solenoid negative and the dark wire goes to the auto switch? If so they need to remain joined together when you pull them off C.
Photos of the wiring from C to the switch and from the switch to ground would be useful to make sure I'm not leading you astray in my assumptions.
I'd do a visual inspection of that path from C to switch to ground, make sure there are no crusty connections, and even test the switch in isolation.
Once happy retest. If it still won't hold (or even pull) you can try a chunky jumper wire across the various segments of that ground path to see which segment needs jumping to make it hold. (not using that thin black wire from the photos that's going to burn up or introduce more problems).
this should read; obviously the "coil" is grounding the circuitobviously the could is grounding the circuit
Sorry, been off for a while... It's good progress that you've got everything working outside of that auto-idle board, so can now focus on that board as the remaining fault. The fact that the revs pick up in when an arc is struck, suggests that at least the main SCR that switches the solenoid is probably working. I see you've started a SCR test thread, so worth checking them all for sure.
Did you resolve the fact that you were only getting 10V to the coil - or did that go away after sorting out the travel issue so it isn't drawing 20A continuously?
