The Rays don't even make to the adf. The clear outer lenses are made from Perspex. Arc Ray's can't travel through it. You could take the adf out altogether and (if it was possible to see) strike up with just the clear outer screen in and you won't get burnt.the lense on an auto mask is just a protective bit of plastic, all the light filtering happens in the auto dark unit
No!! It would be impossible to weld and while it can't burn your eyes light that strong would probably damage them in other ways over time.But don't
It doesn't take too much time.a friend did an hour long test with a cracked glass filter,with a clear lense behind it.couldnt see much for two weeksNo!! It would be impossible to weld and while it can't burn your eyes light that strong would probably damage them in other ways over time.
Hell fire. I've had a few red/green dots from a flash behind a lens but thank goodness never that bad. Tbh whatever the science of whether the light can or can't get through I wouldn't want to use my peepers as Guinea pigs to find out.It doesn't take too much time.a friend did an hour long test with a cracked glass filter,with a clear lense behind it.couldnt see much for two weeks
My son keeps welding by closing his eyes......I keep telling him not to . That is the real reason I was a decent mask to be honest...
Can it? not that I ever did it much but I knew people who did this a lot tacking upNot to mention the arc CAN burn through your eyelids so double whammy.
Afaik the skin on your eye lids isn't enough to filter the Rays but I could be wrong.Can it? not that I ever did it much but I knew people who did this a lot tacking up
it doesn't travel through glass, many welding lenses are glass and you will never get a sun tan in a green houseIf you've got arc eye you haven't got it looking through a welders mask despite how cheap they are the outer/inner lenses are made from Perspex and the Rays cannot penetrate Perspex. You can't get arc eye through clear safety glasses. It can travel through glass though so your every day specs won't stop it.
Point been if you've got arc eye you must of got it with the mask up.
I thought glass welding lenses had a particular type of filter glass?it doesn't travel through glass, many welding lenses are glass and you will never get a sun tan in a green house![]()
yeah uva but not bI thought glass welding lenses had a particular type of filter glass?
UVA definitely travels through glass but i thought the harmful UVB rays did too. Could be wrong mind as the green house thing makes sense.
