Wow. Great thread chaps!.
And a great response from you, if I may say so. You raise some excellent points.
>Small, cheap arc welders...rubbish duty cycles
>do mean that running anything bigger than a
>2.5mm 6013 rod is a pain.
Yes, mine started to cut out whilst on maximum and it takes a good couple of minutes to come back on, so it wouldn't be practical for professional or big project work.
>Duty cycles btw are improved less by cooling
I will play around with extra fans sometime and see if it brings about any improvement in practice. I guess a golden rule might be to use any arc welder at only about half its maximum output, so it's operating well within its rated capacity.
>Also, a basic low end transformer and choke
>will not give the best arc control
I'm fairly sure my arc welder doesn't even have a choke. It seems to be a single large transformer block, and very little else!
>You have only to try using a better plant to
>see what the difference can be.
I look forward to trying that someday and perhaps I'll be pursuaded. The other alternative might be to modify mine somehow, e.g. by adding a choke if you think that might help. I already intend to modify it to drive down the minimum current whilst increasing the voltage.
>Snowcats argument over types of rods that
>can be used is also valid.
I've only used 6013 rods. What should I try next, would you suggest?
>George's old welder friend who doesn't like using
>DC on steel is talking, frankly, claptrap. Sorry
>George, but he is wrong.
You might be right. He's retired now and means well. I guess his main welding period was in the 1970s. He simply turned his nose up when he saw my DC inverter and said it was not good for steel. I then found that the AC transformer unit did seem to produce better results but perhaps I'll go back and look at the DC inverter more carefully after the various suggestions here. Also, it's only a low cost Chinese inverter so perhaps that makes a difference, also.
>Why you also prefer ac over dc for steel I
>do not know, other than the possibility
>that the rods you use don't run well on DC,
>which would be unusual, to say the least.
Striking the arc was much easier with the inverter until I learned the knack with the transformer so that's now a score draw.
Secondly, and the main reason I bought the inverter, is that the current will go much lower and this is of interest in trying to go against the odds and weld thin sheet with the arc rod. In the light of your comments, I will go back and re-assess everything.
>Running a dc weld off a few car batteries
>in series is much nicer than the weld most
>buzz boxes give.
Thank you for this suggestion. Do you need anything other than about 4 car batteries, to get up to about 50 volts? But isn't the current too high and likely to blow holes, even in 2mm or 3mm plate?
>An oxford/pickhill oil-cooled set would be by
>far the best and economic (though not the
>lightest) solution.
I may look out for one of these too, to see what they're like. But aren't they AC, like mine - just oil cooled and heavier duty?
>PITA when it comes to changing the current, and
>constant current adjustment is vital if you are
>going to do consistently good quality welds
Thank you for this tip, also. I knew about current adjustment for TIG but I didn't know it was done for arc welding.
>Welders with clicky knobs (technical term)
Do you mean they avoid the need for a movable core by having various windings, or resistors or something?
>budget weld set. It does a job, at great value for money.
>It probably beats the cheap and nasty inverter which
>looks good, but has lots to go wrong, and will.
My inverter is guaranteed for 3 years and I only intended to use it on low current settings in the hope it will be under less strain. For anything heavier, I intended to use the transformer unit. But it only cost about £50, so I have little to lose and look forward to trying 'entry level' TIG.
Try some Murex, ESAB or Oerlikon.
