I had to cut it out of the original frame due to total seizure.
Why didn't you just put a hacksaw blade through the alan-bolt?
Why didn't you just put a hacksaw blade through the alan-bolt?![]()
George, seriously DO NOT TRY AND WELD THAT STEM BACK TOGETHER!
Chances are (given the origonal wheel size mentioned back when this all began) the frame is a simple steel, rather than a posh alloy steel.
I ... will not be welding that part. I'll glue it instead
Trying to glue it is even more daft/dangerous!!!! Take up Alfaman on his kind offer (assuming his stem is the same diameter as yours) or buy a new one! Even if i'm right (and it's an educated guess based soley on the fact that the wheel sizes mentioned don't really go with lightweight high end bikes) the comments about the steel welds are still relevant, it's just a case that if it is a simple steel it'll be 'damaged' less than a posh alloy steel- the HAZ is a little less of an issue but plenty of other potential problems remain
Good joke! George, you do make me laugh.![]()
Glue is used in many 'serious' industrial applications. I won't hesitate to use it if a replacement is not as good as the original part.
As for potential problems - if my bicycle frame really is mild steel, then what about some of the amateur welding jobs we see on cars at this forum and on other sites? At first look, you'd think the rust-riddled vehicles should go straight to the scrap yard but, no, someone with a MIG welder uses miles of MIG wire to replace acres of steel sheet. All those new joints may not fail an MOT but is the resultant vehicle really safe? If those vehicles were put through accident crash testing, how would the restored bodies stand up to simulated impact damage?
OK - because I relish the challenge/gamble of trying to prove people wrong, this is what I'm going to do, just for the hell of it!
Why do it then??
