123hotchef
- Kent
oh powerfiles too now huh!
5 die grinders 1 x 9" cause its scary! 6 x 4.5" 3 x 5"
ha ha i have a hitachi 9" its great to use just heavy and jumps when u start it up, great for grninding metal road plate even better with a dimond disc on it for stopneMy 9" Bosch is actually very nice to use. (I just bought another which i think will be just as good.)
But put a 4" cup brush on it and you need to hold on for dear life. Absolutely awful thing, the vibrations could shake your limbs off.
Got 2 of those, 40G and 80G. Only cheap Silverlines but they're really good.
maybe i shall invest in another any suggestionsYou need a nice soft start vibration reducing one! So much nicer to use.
115mm x1; used for metal cutting, metal grinding, metal flap disc work, poly disc work on metal, poly disc work on wood and soon... concrete grinding.
I need more grinders lol
Think I should join in too
One off Hitachi 5”
Four off Makita 115mm
Two of Makita 9”
Once you've had multiple grinders and multiple sockets to plug them into, no swapping discs or plugs, you'd never go back to just having one.
7 grinders. That's more like it!
When I did some welding with a friend, I brought my own grinder so we had his for cutting and mine for grinding. So much quicker and more pleasurable to work that way.
I’ve got some air grinders too, but they don’t really count as I haven’t got a compressor man enough to run them
Air grinders are horrendously hungry little things. I have a couple Ingersoll-Rand industrial die grinders and they'll empty my 200L compressor in a couple of seconds. You need a really big industrial compressor (Like a screw-type or Hydrovane.) to keep them fed at full tilt.
Great tools though, huge amount of power in such a compact tool. I'm sure my IR that's ⅔ the size of a coke can is more powerful than my 240v Bosch that's 3 times its size.
Little air pencil die grinders are great too. Can't beat them for cutting out snapped studs in cylinder heads or broken glow plugs.
I only have 7![]()
