It went bang because they would have destroyed it as soon as it was out of control ... from the video it appears to loose normal flight shortly before it went ... I don't think it self destructedOf course there is always the possibility that the reason it went bang, was that it achieved MaxQ to quickly...........
How about a jet powered blower?Do you know what would really suck?
A rocket powered vacuum cleaner!
I read somewhere that the locks of the rocket and the ship should open, after a small forced impulse, to rotate the ship itself. And not during a pause, when all the engines are off.These things are built as close to the material and component failure limit as they can be... once they get into flight bodies. Unfortunately that means you get to test everything to destruction sooner or later .... having tested all the sub assemblies you then get to do it all again with the final product
Cad/cam/fea and rigorous testing still fails to show every potential issue..
All that failed appears to be part of the separation sequence... a line of code a faulty switch a bad connection a bit of ice .... a failed actuator?
Do they still use explosive bolts ?
The rocket made an aerobatics "dead loop" like an airplane. Engine thrust was enough. The problems started at the separation stage. I saw a poor quality photo, where on the launch pad, nothing was left of the concrete, only a pit. If so, you need reinforcement. After the last test of the engines, the concrete was changed to high-strength. It is not clear to me, as a novice welder, why not cover the launch pad with sheets of armor or other heat-resistant steel, in the "tile" format.Seems likely that the engine damage skuppered the flight as they may have lost full control.
Wonder if it was damage from the pad...so maybe nothing on starship went wrong!
Plume temp is itro 2500c I guess.... nasa used huge volumes of water to help minimise damage iircThe rocket made an aerobatics "dead loop" like an airplane. Engine thrust was enough. The problems started at the separation stage. I saw a poor quality photo, where on the launch pad, nothing was left of the concrete, only a pit. If so, you need reinforcement. After the last test of the engines, the concrete was changed to high-strength. It is not clear to me, as a novice welder, why not cover the launch pad with sheets of armor or other heat-resistant steel, in the "tile" format.![]()
True, most of the “smoke” from a NASA launch is actually clods of steam from the water used to cool the pad.Plume temp is itro 2500c I guess.... nasa used huge volumes of water to help minimise damage iirc
