Erie Fred
- Erie, Pa USofA
You worked it so hard, it was caught sleeping on the job.....
A service engineer generally flies under the H&S peeps radar due to them being on site for only a short while also depending on who/ which sub contractor your working for, you may not even have to sign in at the site office. When I was involved with Steel Craft (or what ever name they're using these days) I used to phone the site shift manager/foreman and meet him at the delivery gate and get taken straight to their compound on site. I was then shown the location of the machine and left to fix it.How do you get on cutting wood up on site with a chainsaw?
Assuming you’ve got the ppe and tickets they still get a bit twitchy about them.
Only a gov org couldYou couldn’t make that up.
Have you opened it up to see what size motor? I probably have a spare. If not, the motor from one of Aldi's cheap brushless angle grinders or similar might work quite nicely.At least yours has a top guard over the blade, unlike mine. As I said I pushed mine too hard and cooked the brushed motor:
A friend remarked that there's probably a good reason they're called "one handers"!
Let's be careful up there!
Seen these cant really tell size from the pics and it doesnt say much. Less power than the Stihl 261.. and looks weighty? 7.5kg..
45cc says 7kg, 18" bar..
Are bars and chains pretty standard, could I swap for an off the shelf 10" or 12" bar?
Yep you just need to know the bar mount type easy to work out once you have the original barAre bars and chains pretty standard, could I swap for an off the shelf 10" or 12" bar?
The 8 inch bar and chains arrived but chains too long needs atleast two or four links less. The idler wheel rivet is also not ground flush with the bar.
This is 1/4", 1.1mm, 48 drive/24 cutter.
I think I want 46 drive and 22 cutters.
Anyone shortened a chain? I can turn a new rivet easy enough, easier than sending back as its from ebay.
You should be able to use the original ones againYeah thats the easy bit.
What grade of steel should I use? I assume needs to be soft enough to peen but durable and strong?
Yes it would however Im aware that 1/4p 1.1mm G chains and particually this length are a bit obscure and Im not expecting to find the correct one.Considering the speed that the chain flies round is it not worth the literal pence that a joining kit would cost from your local garden machinery place
Its going to need a new pin after I have ground the head off to punch them out.You should be able to use the original ones again
You don’t grind anything thing off. A punch with a point deals with the rivetsIts going to need a new pin after I have ground the head off to punch them out.
