this sounds like the right one then
It would be worth getting a wiring diagram for that motor just in case, I bought 2 identical used compressors and one of them the motor didn’t work and had been messed about with, when I checked the wiring against the one that was working they were wired differently, copied the wiring from the other one and it ran fine with the belt off but would only run for about 20 seconds with the belt on then it would slow down, stall and I could hear the motor buzzing, pulled the plug before tripping the CB or seeing magic smoke, couldn’t see anything wrong with it when I stripped it so bought a new motor, Machine Mart was the cheapest price I could get for a new 3hp motor.good spot
there a chance they might have put the connections on the wrong terminals
where would i find the diagram?It would be worth getting a wiring diagram for that motor just in case, I bought 2 identical used compressors and one of them the motor didn’t work and had been messed about with, when I checked the wiring against the one that was working they were wired differently, copied the wiring from the other one and it ran fine with the belt off but would only run for about 20 seconds with the belt on then it would slow down, stall and I could hear the motor buzzing, pulled the plug before tripping the CB or seeing magic smoke, couldn’t see anything wrong with it when I stripped it so bought a new motor, Machine Mart was the cheapest price I could get for a new 3hp motor.
Hopefully you won’t need to go down that route, I thought the problem with mine was the start cap a new one didn’t help though.
If you mean on the capacitor it doesn’t make any difference which way you connect it.there a chance they might have put the connections on the wrong terminals
looking online a knackard capactor can damage the motor make it run hot possably melt the windingsIf you mean on the capacitor it doesn’t make any difference which way you connect it.
With the pressure washer motors I work with that capacitor would have been replaced long before the capacitance had dropped that low.
ive no idea on what oil will have to cheak around it see if any thing on it any where as ive not go the id on the compresser to do a google searchNo harm in changing the oil while it’s down, SAE32 ?
Quite possibly,screw top right is the pressure shut off
the screw head to the left id guess is the start one ?
ah got you might have known it might not be as simple as ones the stop pressure and ones the restartQuite possibly,
So with the compressor flat, I'd suggest turning it 1 complete turn (mark the screw head with a bit of RED paint to indicate a starting point) then run the comp and see how it affects the stop start.
Its possible the two adjustments may interact... ( that is the pressure at which it starts and stops, you may need to adjust the Stopping setting..)
