Thanks for your reply. The regulator on the compressor only has a 1/4" fitting so will that not also cause restriction on air flow regardless of hose diameter?
Another worry I have when thinking of buying another unit is cfm. The airmaster has 8cfm which should be adequate for the wrench as the manual says 5.6cfm required. I understand most compressor run slightly less then what is stated but what would be the recommended cfm for powering air tools such as a wrench, ratchet and grinder?
Yes , that is restrictive , but a hose that is too small will restrict even further.
When I first discovered this problem we were having the same difficulty with a new Snap-On impact gun. We were expecting to be impressed by this new expensive guns power but the first time we came to use it on some van wheel nuts it just wouldn't move them. By pure chance next door was having their compressor serviced and the engineer heard us having a moan about the gun. He took one look at the hose , which was quite a long 8mm bore and said the hose is too small and too long , go for 1/2" and shorten it. We did it there and then , result , wheel nuts straight off without even using full torque on the gun !! Our compressor was quite a large capacity , about 25 CFM , the reg was set at 90 PSI or about 6 bar , which is normal operating pressure for most air tools. So , even that fairly big compressor didn't help when the air feed to the tool was restricted by the hose.
