well go look up the specs for each radiator output . yourself dont be lazyI was hoping for a more quantifiable answer than 'lots'.
well go look up the specs for each radiator output . yourself dont be lazy![]()
I think you are being a bit silly in your responses, it is the type of question difficult to give a precise answer to with such little information.That's an answer to a completely different question. Without knowing what the output of the radiator i'm replacing is, how would I know how much difference it would make?
I'll repeat the question: How much difference would a modern unit make compared to something 40 years old?
How would anyone else know the difference then?That's an answer to a completely different question. Without knowing what the output of the radiator i'm replacing is, how would I know how much difference it would make?
When you find the 5000btu size rad comes out larger than the existing one you'll know which figure is right.I've used two different BTU calculators. One said 2000btu, the other said 5000btu. I'll err on the side of caution and go for the largest one I can fit.
ignore the btu as the new numbers reduce the size of radiatorIf the original radiator was sized correctly, and the new radiator is sized correctly, the answer will be no difference at all.
The difference will be the cleanliness of the system, as old radiators are probably corroded and sludged up.
