Have you looked at using a needle scabling gun on the surface, this would give a preened finish, not unlike blasting, but without the inclusion
Hi There
A very interesting thread. Thank you for sharing your results.
If blasting plastic with aluminium oxide, will it need cleaning with the vinegar before painting? I am guessing yes!
Many tks... Berni
have you tried baking soda yet ? it just washes off with water
...we used to use a company called vixen,for blasting supplies and equipment....VIXEN ....we used to blast alluminium and changed to their aqua blast system,they had a trailor set up for demonstrations maybe they could suggest a different approach .....good luck
Hi Kat ,sorry i've missed this thread...we used to use a company called vixen,for blasting supplies and equipment....VIXEN ....we used to blast alluminium and changed to their aqua blast system,they had a trailor set up for demonstrations maybe they could suggest a different approach .....good luck
I am therefore currently looking for tips on improving the surface finish using shot blasting and also on testing the surface roughness after blasting. I am thinking we will need to hire/buy a surface roughness testing machine of some sort. Any ideas where I can do this?
Thanks for all your help so far everyone.
Would making a simple pulley and weights device with high quality abtec bearings ( or even air bearings allow you to carry out coefficient of friction tests ie a known weight dragged over a surface from first movement to stopping using a standard set pulling force /weight ?
Could you use a microscope to measure the peaks and roots of the abraided cross sections in microns of the various materials and then make up your data charts from both readings ?
If it were a set magnification and presented on a Monitor screen via a camera set up you should be able to work out the measurements especially if you graduate the screen view with a know scale derived from using a known test piece thickness
I work for an NDT supply and service company and we occasionally get asked for surface roughness standards - but they're usually for checking machined finishes, nothing as fine as you're asking. However, I can do some digging tomorrow and see what I can find. I'm guessing there'll be some optical magnification involved but it may still be an operator's personal judgement, rather than an absolute measurement, kind of technique.
Vixen at Thornaby is only a couple of miles from me; they've always been extremely helpful when I've needed abrasives, or parts etc..
As well as advice on roughness testing these firms may be able to give advice on treatment, or at least point you in the right direction, worth asking them.
