You have nothing to lose, have you. I don't think it will give a rougher surface, more of a preened finish, with the added benefit of no inclusion, but then I could be totally wrong.
Give it a go.
Looking at Guysons site I would call them and ask about the Metalic range, Flexgrain or better still Turbonox looks like a good media to try.
Have you spoken to them at all?
Thanks, it would be great if you could let me know if you found out anything from work.
To save me rereading the whole thread how are you making these
They are being fully machined on a CNC router using standard slot drills.
Thanks
Hi Kat
I think that is part of the problem! Your specification is a grinding tolerance and the process being used to machine is milling. Depending on the speeds and feeds in use at the milling stage will depend on the results obtained. But they will be prob be going for material removal rather than surface finish.
The spec of 0.8Ra is a bearing grade finish.
Check here
http://icrank.com/cgi-bin/pageman/pageout.cgi?path=/data/surface_finish.htm&t=2
Cheers
Kevin
just a thought cant the blasting be done in 2 stages with diffrent grade media . one to take the marks and rough edges off then a finer media to smooth off.Thanks for the link Kevin, a very useful page. We are using milling to make the part because we are going for removing material at this stage in the process. We are starting off with a sheet of PP which we are then milling to make a disc with lots of intricate details on the surface. Due to this material removal (which is necessary) the surface of the polypropylene is then left with machine lines. It also needs deburring around the features. We have therefore been looking at blasting to remove the lines and deburr, and we have achieved this, and when looking at the product it appears to be smooth. However, it is not quite smooth enough when surface roughness testing has been carried out. We are therefore continuing our grit blasting trials and trying to tweak various parameters to get a finer finish.
I am also looking into alternative techniques to blasting such as using chemicals, so any suggestions would be welcome
In a worst case scenario we will be sanding the part down by hand, which will take a few days.
