julianf
- devon, uk
A longer stack (if possible) would give more draw.
I would imagine that it would take a long time for the flue to get hot, given that the hood can suck in so much cooler air from the surrounding area.
Sometimes, on a windy day, our log burner will suffer from down draft as its being lit. If that happens, i get a load of newspaper (which i dont generally use to light it) and load it up with that. It gives off enough heat, quickly enough, to heat the flue enough, such as it draws hard enough to counter the wind / down draft.
Im not sure how you could do this on the forge, but im mentioning in case you come up with anything!
