They are - short days and some of them very dull, but there is still some useful sunshine to harvest, we have averaged approx 13kwh per day so far from our 7.3kw system this month. Some days poor, some days very good. The battery makes a huge difference:-)Hurry! The daylight hours are slipping away!
Good luck - generally this time of year you will be at 10% of the best (summer) days. So, @brewdexta don’t be too disappointed when you see what you’re getting. If you’re lucky enough to get some frosty weather later on they will work well, despite the sum being low in the sky.They are - short days and some of them very dull, but there is still some useful sunshine to harvest, we have averaged approx 13kwh per day so far from our 7.3kw system this month. Some days poor, some days very good. The battery makes a huge difference:-)
Looking forward to a bright November.
3.8kW will net you 4000 kWh a year in a good year. Your target I guess is to capture and use it all. Looking forward to your posts.
I put a Gatemate lock on the solar shed door earlier. I was cursing because the lock barrel diameter was a funny size, just over an inch. I eventually found an old hole saw that did the trick. Then going through the box for the screws, I found the 27mm flat wood bit that comes with it. doh!
With the current price you are definitely winning!This years total (according to Fronius inverter), 3970kWhs. Will I scrape 4000, my best ever year?
Not bad for a 12 yr old single string system.
You’ve made me slightly jealous with those Numbers, average 300kWhs more than my install. That’s £150 a year for me...Happy with the apparent lack of degradation with mine. Obviously it's dependant on weather too but, considering they have never been cleaned, seems ok.
Not quite up to brewdexta's level of datalogging though. I can't even manage to take an in focus picture!
With that rate, you shouldn't be. I can't remember FiT rate, but it's not 50p!You’ve made me slightly jealous with those Numbers, average 300kWhs more than my install. That’s £150 a year for me...
