Craig-SM
- Heckmondwike
After looking into the cost of them (none in the stores at work at all), thats what i decided on. Made up the anchor and hardened the shackle, quenching it in oil. Its a good thickness anyway so am confident in it, just the fact it's there.
The chain itself is either Chromoly or Chrome Vanadium one or the other and the links are 14mm thick so should be ok. If someones going to nick it, its going to happen, just wanted to make it as awkward as possible so acting as a deterrent if anything.
A 14mm chain is no deterrent as it will be cropped pretty quickly and offer no problem to an angle grinder.
If you want to keep your bike then invest in some proper security with an Almax or Pragmasis chain and ground anchor. I would also recommend a security pin if you can use one on your bike. Try not to have the chain on the floor to avoid freeze and hammer attacks.
My uncle lost his HD Fatboy to thieves who made easy work of the huge 25 tonne shackle he used for a ground anchor and with little noise so not to disturb the neighbours during the day. Due to this I upgraded my bike security to Almax chain, anti pinch pin and Torc ground anchors. With the bike tight up to the wall the chain is secured to the bike three times and to two separate ground anchors. Their is no space to attack with a meaningful size hammer, oversized for hand operated bolt croppers and even though an angle grinder would still get through them eventually the access to so is very restricted. Even with all the fixing points it only takes 5 minutes to secure or remove the chains with the use of bungee hooks to store the chain when not in use. Since then I have invested in CCTV due to an attempted house break in, sash jammers prevented access, and now a large Alaskan Malamute.
