Carl Wilson
- Moray
Because in the real world where Joe Bloggs is screwing a bracket onto his milling machine, interchanging BSW and Unified makes not a jot of difference, the tolerances make sure of that.
I'm also in aviation and wouldn't dream of using the wrong thread system at work, at home in the workshop it's not always so easy to differentiate between 55° and 65° on a 1/8" diameter fastener...and some manufacturers have BOTH systems!!
You are getting all worked up about thread systems and paying no mind to the other critical part of fastener makeup...material. it's just as important for a fastener material to have the same physical properties as the one it is replacing but you've very little chance of finding that information most of the time.
You wouldn't have used soft solid rivets in place of hard and vice versa (unless of course your maintenance documentation allows for such)
I can categorically promise you I'm not getting "all worked up" about thread systems. "In the real world" I'm currently stuck in the US and I cannot get back home to the UK where my family is, in the middle of this unmitigated hell we are all currently living through. So fasteners are the least of my problems.
I've been through much worse though. So I'm sure it will turn out fine in the end.
