Hi RobertThe board basically has two circuits on it.
The 220v power relay that is powered by the 24v PCB transformer and switched by the trigger switch.
And the motor drive circuit, that uses the welding output voltage to run the motor.
The relay on the PCB does click when the trigger is pressed ?.
A transistor of the type on that board looks like this.:http://www.fairchildsemi.com/ds/KS/KSP42.pdf
Robert
any chance this could be the problem?KBP206 is a bridge rectifier.
test if there is a dc voltage coming from it where it has the + & - you can also check it has ac going in where it has these signs ~ if it has a dc voltage coming from it, it should be okany chance this could be the problem?
hi could you send me a link to this for sale?88 quid!You should of give us a shout, 60 odd & off the shelf!
Hope it does the trick.
