Hi thankyou for the advice!This thread is 9 years old!!
@Jake fox weldequip’s contact details are at the top of the page, he doesn’t reply to threads any more.
I am dealing with intermittent wire feed issues which has now settled into a consistently not working at all situation in a mactool 230v mig welder which i had running thanks to this forum (main ssr was toast) and then all the sudden the wire feeder kinda would sorta run, stop and then I’d adjust the feed POT and it would slowly start running again and gain rpm then kinda stop and sometimes just start up again, etc.. all the while my gas solenoid and relay are still working with trigger pull and I’m nearly 90% sure my electrode would still arc. I could heard the machine humming and at different levels adjusting the heat control POT while trigger was engaged.The usual failure would be the output transistor.
If you could post a photo of the PCB,maybe someone could suggest a few tests or cheap replacements to try.
Robert
More reason to stoke up. Lol. I don’t think the age of a forum or discussion takes away from the informational value or helpfulness it can offer someone such as myself. Are you suggesting I should have created a sort of semi- redundant new post and maybe sighted this n thenJmac5571 this thread is 5 years since !
That's an interesting component. I researched it and now think that it is a "Thermal Fuse". If the transformer overheats the fuse will open at a preset temperature ( which may be marked on the component ).I’ve simply removed insulating tape from coil to check coil condition and also pulled out a thermal resistor, or at least that’s what it seems it is to me
No not at all was trying to be helpful informing you that you may not get any conversation , but I was wrongMore reason to stoke up. Lol. I don’t think the age of a forum or discussion takes away from the informational value or helpfulness it can offer someone such as myself. Are you suggesting I should have created a sort of semi- redundant new post and maybe sighted this n then
