Jamie nixon
- Barnsley
I always seem to have a brew on the go either lager woodfordes or a turbo cider.
I need to build a rocket stove.
Start to finish, a batch takes me about 4.5-5 hours, but I can do other things in the meantime as most of the process is setting up the next stage, then leaving to go for an hour or so.Its the time that puts me off starting. I think theres a load of good kits out there my local shop https://brewathome.shop/ has loads of the kits avaliable
I have for now, as time is limited for me.You stopped now? Theres some good beer and lager kits out there nowadays
calling @gaz1I need to build a rocket stove.
You could just try drinking less of it .... ?Thanks for the replies, I feel a low alcohol brew might be on the cards for Christmas then
What sort of an option is that?.You could just try drinking less of it .... ?
I've not brewed for a few years but used to use this recipie (or similar), for mead which doesn't need boiling.Well I just bought 4lb of local honey to make mead. Still need to get a big, induction hob friendly, pot:
