rcx132
Philip
- London, UK
I had the compressors running half the day yesterday, it's really unfair on my neighbours, they put up with so much already.
I'm thinking of moving them to the far side of the garage, further from the houses, and the garage will block some of the sound.
At first I thought about buying one of these... But now I have three compressors (one big, two small) they won't fit and I'm also thinking something sound proof, moving the compressors out back alone won't fix the noise.
If I go for sound proofing, the popular solution is to make in the inlet and outlet ports go around a corner like this. Is this still the best way? Anyone had much luck with it? Note the grey sound deadening pads.
I'd try to make something pretty:
Ideas for low cost forced air solution? A regular bathroom extractor won't cut it.
At my last workshop, the compressor pump was in a box inside the workshop with a bathroom extractor. The extractor wasn't cutting it. The box was not insulated and made little difference, but being inside the workshop made it quiet enough for the neighbours. This workshop doesn't have space so the compressor is outside.
To save on doing a concrete slab I was thinking of using fence post stakes and concreting them in. The cabinet would then be suspended above the ground.
