JMS1972
- NW Leicestershire, UK
Here's a few things I've done to my CO2 laser. These are sold on eBay and Amazon for around £300. The generic name is K40 and a quick Google search will pull up loads of web sites dedicated to modding these.
They are sold as 40Watt lasers but the length (which affects power) is too short so realistically they are 30watts.
Max usable size is A4 but only if you move the limit switch nearer the back.
I've added air assist which performs two functions it increases cutting power (think blowing on embers to get a fire going) and protects the lens from smoke.
3D printed nozzle. Air bleeds into the central cone as well as to tip of nozzle.
Runs off a beefy aquarium pump.
The best beam focus was a few mm off the bed so I use nuts to raise work up and also as end stops round the edges.
The brown tar is a feature of cutting MDF and plywood. Hence the need to improve extraction.
The extraction port was filled with some packing foam to only extract from above the bed (work is raised up so smokes on underside). The standard fan is backed up with an axial 4" high flow extractor venting outside as the smoke is surprisingly very toxic
