Should that not be the other way round? 5.1 has a higher boiling point than 4, which is the main criteria for brake fluid.I would go DOT 4 all the way in your application duck , As the brakes won't be pushed hard enough to warrant racing fluid(DOT 5) and 5.1 is not as good as DOT4, just don't spill any on your paint .
Errm yes! well spotted, You passed the testShould that not be the other way round? 5.1 has a higher boiling point than 4, which is the main criteria for brake fluid.
But come on, In a road based landrover or any land rover for that matter, Unless your planning on doing the pari dakar rally raid, DOT 4 is gonna do the Biz.
Brake fluid manufacturers can and often do improve on these figures and it is possible to find DOT 4 brake fluid with a higher boiling point than some DOT 5.1 fluids on the market.
It's got to be worth pulling it apart and taking the bits to a hydraulic engineers to see if they can match the seals at that price?It's mixing them that can cause problems. Just had to change the master cylinder on my Thwaites 2 ton dumper truck, as someone had put DOT type fluid in, but as it's a wet brakes machine (ie disks immersed in the axle oil) it uses mineral based LHM fluid. The DOT reacts and jams the seals - no seals sold separately for the Frenos Iruna Spanish cylinder - £165 for a replacement
tjheres not a lot of breaking on modern engines as the flywheels are -nowhere near the size they used to beTowing shouldn't require the vehicle brakes to do any more work, overrun brakes should take care of the entire trailer braking.
But in the real world (and rightly or wrongly) there are huge numbers of trailers out there with inadequate or totally non existent brakes which do put the braking requirements on the tow vehicle. If driven sensibly and properly this needn't require prolonged application of the brakes needing a system that can cope with high temperatures, you should put the vehicle in a low gear and let the engine do the braking - and enjoy the scenery as you pass it very, very slowly - towing is not about rushing.
People who put heavy unbraked trailers behind their vehicles and go down hills with their foot on the brake keeping the outfit at a slow speed are at high risk of boiling the fluid.
It isn't that I don,t Think, I know, I build and race cars that have their brakes on fire, And have towed some stupid weights in daft conditions with a special types HGV, So its more than just an educated guess.Can't believe you don't think a 4x4 would not be heavy on its brakes if nowt else they are the best towing vehicles which puts loads of strain on the brakes....
