Whilst that may seem a bargain its an old machine with no service or support backup if something goes wrong. Mine has played up a few times, but luckily ive managed to resolve the issues.Second hand fronius transpocket went on there for 150 notes the other day. Bloody bargain.
If your ever down this way or can get someone to pick it up, I have a 140a stick welder you can have. It did have fixed leads, but I cut them off to use on another one, so it wants some leads reterminating. It's an old French one, according to the front, has copper coils in it & unusually has some form of electronic control, not the normal sliding transformer segments.
I've had it about 25 years & it wasn't new then. Yours if you want it, but too heavy to post.
This any more interesting?., 172373497164 Any use for ally?
Thanks for your help.
If you want a cheap mma welder for occasional use why not buy a buzz box. You'll get one in Aldi/Lidl for £40, when they have them in and come with a 3 year no quibble warranty. Not that they will go wrong as they are so simple, no electronics to worry about. Ok they are not as nice to use as an inverter but will still stick metal together in the right hands. I used one for years and nothing I made has fallen apart yet!
If you are spending £100 on a welder why not consider a used Oxford or Pickhill oil cooled set. Very nearly as easy to use as an Inverter and you'll never have to worry about exceeding it's duty cycle. I would guess those cheap Chinese welders would have a poor duty cycle & you'll spend more time waiting for the welder to cool than doing any actual welding!
Its designed for somewhere like Japan, look at the rear, bottom right corner is an earth symbol...bit of a chinese abortion tbh
I have something like : http://www.ebay.co.uk/itm/ARC-WELDE...OFFER-LAST-FEW-2-YEAR-UK-WARRAN-/311723435923
UK based seller and UK registered for VAT so someone at least to sic trading standards / lawyers on if needed...
Had dealings with him, never again I am afraid.
First tig went on fire first switch on, replaced next day delivery with another, I took ill and was in and out of Hospital for 3 months so only managed a few hours welding with it when it blew up.
Asked for a refund, sent it back and never heard. Contacted and they said it was damaged in transit so to claim off courier, pics they sent showed damage to the box lower corner and damage to the welder was totally different position. Knobs supposed to be ripped off but closer inspection of the pics showed indents where set screws had been but no groove where they supposedly got pulled off, in other words they had been unscrewed before removal.
I said I would get it collected, courier went there 3 times and each time they said there was nothing to collect.
Anyway that is my experience of them, maybe others have had better experience but I wont be dealing with them again.
They're a good welder, well regarded on here. But for ally you need an AC TIG (the Parweld is DC) and they're big money.
Yes. But that is alloominum he is welding ! Not available in Ireland or the UK nor mainland Europe either.This guy seems to weld ali with a DC unit?? see the link on post #10 http://www.mig-welding.co.uk/forum/...m-this-thick-with-a-170-amp-mig-welder.67653/
Had a reply from seller:-
"Hi there
Thanks for your message
My friend, you are correct,this welder has 2 wires to be connected,there is no cable to connect the earth.
Best regards
ALLEN"
Yes you can weld Alu with a stick welder but it is hard to do and results are crap when compared to Mig or Tig. It could get you out of a bind as an emergency repair but that is about it.
You can if I remember rightly correctly tig weld aluminium if you run straight helium gas.
