There is no way I would take a vehicle out on the road I'd just 'rebuilt' with little or no protection from the environment, especially at this time of year.
If the testing station wanted to see the work 'clean' on the retest then that's fine if they actually inform me at the original test, but it will be painted, if not undersealed.
My testing station has never asked it of me but I do know of a Metro owner (that's how long I've been using them) that was told that the work would have to be inspected so leave out the appropriate carpets and trim!
Yeah, I was thinking along those lines too, that were the whole point of my question really. If you took it to another station for a fresh pair of eyes to look at the vehicle, how would they know anyway.
mot tester needs to be able to see it's fully welded that's all if it's total covered in thick tar under seal so he can't see the welding
he can either fail it or ask you to remove the under seal so he can see the repair is fully welded coat of red oxide would be OK
Thats a bit harsh considering the original was spotted along there - but in the end its up to the way the individual tester interprets the rules.
Still no great loss, and nice work BTW
we (2cv club) are having difficulties with VOSA as the new regs for MOT specify that a Hi beam warning light is now testable ( amongst other things)despite our cars not having one fitted originally.
Sean
Car went ion for MOT yesterday and failed because I only plug welded the bottom flange (where the inner and outer sills meet). It needs to be fully seam welded. There were some conflicting remarks in here so I thought I'd just clarify that.
Sorted it yesterday afternoon so should be good to pass at some point this week :-)
Thanks for all the reply's.
the reason if failed is because it was a repaired panel not a replaced panel
if you fitted a full sill then the bottom edge could be spot /plug welded as per factory so if in doubt fully seam weld it
and as from jan lots of new mot/vosa laws come in only advisory till march then fully part of the system
Sean
but the Vosa information states that after the 1sr April '86 ALL cars should have one.if it's not fitted as original they can't test it or fail it for it
Had an entertaining discussion at the MOT station this afternoon when I took one of the Dyanes in for its annual checkup.
It seems that someone in the 2CV world has been stirring things at VOSA, since an item from a document handed out at a recent seminar for MOT testers reads as follows;
“An inspection of the main beam warning lamp is included in the test from January 2012 and it was thought that this would be fairly straightforward as the regulations state that vehicles first used on or after 1st April 1986 must have one.
Then a Citroen 2CV enthusiast threw a spanner in the works by pointing out that they didn’t have one. It transpires that 2CVs were produced until 1990 and after some research we discovered that there were some manufactured before but first used after the ’first used’ date which didn’t have one.
To make life easier for NTs, we have agreed with DfT that all 2CVs first used after 1st April 1986 without a warning light should not be failed for that reason, but if one is fitted, it is testable.”
Tbh, I don't think that they have contacted the correct source, since the main beam and indicator warning lights were never fitted to 2CVs destined for the UK market, although the wiring is there for those markets where they did do the job properly.
Maybe they asked Citroen?
Ken
Methinks the tester needs to have a proper read of the tester's manual.
Regardless of whether it's a full panel or a patch, spot/plug welds are acceptable where they originally were, provided the defective part has been fully removed, i.e. you're not patching over the top.
Looking at the photos, the OP has done that as there's nothing left of the inner, middle and outer sill panels in the area that was repaired.
It's very clearly worded, I'd be very tempted to print if off and wave it in his face.
I agree, the tester has been a jobsworth here or does not understand the rules properly. The OP made a perfectly good repair and was made to fully weld a seam that was not originally fully welded and does not need to be fully welded under the MOT rules.
To the OP - don't go back to that garage, next time find an MOT tester who knows his stuff!
from our own forum
and another is failure as there is no indicator tell lale the repeater can is fitted in such a way as there is an audible "ping" but some testers look for the green light, when "an audible or visual warning" is required
You are up to the discretion of the individual tester - sometimes unfortunatley. Worth finding one that trusts you and you can trust.
maybe the tester could have let it go but the testers manual say replaced panels can be plug welded not part panel see link from testers manual item 10 still a grey area
and here is another stupid one land rover discovery rear body mounts both can be rotted or broken and it's only a advise but 2 mounts on one side is a fail
http://www.motuk.co.uk/mot_appendix_c.htm
In the 50sSean
didn't the 2CV headlamps have a little tell tale that stuck up above the actual headlamp itself so you could see the light was on from inside the car
