Screwdriver
Just to finish this off: the bike turned up today and I ground back the broken casting with a Dremel carbide bit. Looks like the previous stud had snapped off and been ground flush before being drilled out (off centre). Knocked out the remaining half crescent of steel thread and cleaned the alloy.
Then with 120A (foot pedal strapped to a log) started laying down some 4043 beads. Argon whacked up to about 25cfm because we're outside, heavily weighted -ve offset (position 2 out of 4 on the KEMPPI) to give me better cleaning.
Paused in between beads largely because I kept blowing the tip, either where a gust took away the shielding or the awkward angle meant I either dipped the tip in the puddle or touched the filler. Also to allow the head to cool. It never got too hot to touch because the head is of course water cooled anyway.
Once it was filled, filed down to flush and made a little jig from box section to match the existing (badly fitted) stud so I could drill it out and tap. The jig is bolted through the existing hole and lined up by eye, braced with a length of bar.
Plenty of meat on the newly welded piece but just look at the other stud hole! eww. it was tempting to re-do it out of principle but if it ain't broke...
It's a good solid repair though. Job done.
s.
s.
