pandemonium123
- Ayrshire scotland
Would an old turbocharger runing on the flue gasses provide enough air flow/pressure??
flue gasses would not turn a turbocharger at all dont forget an engine is similar to a compressor in that the exhaust gas comes out under pressure
I would have thought that the oil burner would be like a jet engine, the flame will suck air in which will expand as it heats up??
I was wondering whether a turbine (old turbo) could drive a generator?
think of space heaters they are fan assisted and they dont have anywhere near the airflow.
i used to be responcible for a huge oil fired boiler that heated huge commercial greenhouses and the smoke rose up from the flue it didnt come out as though there was a jet engine behind it.
i think its a non starter
i take it no one bothered to look at the link i posted??
http://www.gas-turbines.com/nt6/index.html
clearly self sustaining just a question of how long the fuel would last.
have a look at this for a power take off.
http://www.rcdon.com/html/gr-5a_turboshaft_engine.html
Wow! Thank you and Blackjack for posting those links. I wasn't thinking in terms of a jet engine type approach.
Turbine engines run at full throttle, much like diesels, so as with a diesel engine, you can limit the speed of a turbine by adjusting how much fuel you feed it. I can see fuel atomisation issues with low fuel flow rates though.
Unfortunately any DIY turbine project is unlikely to be "quiet" so I believe extracting usable power at sane volume levels would be quite a challenge. One would have to contain said turbine project in a soundproof and fireproof box.
Extracting usable power from the turbine exhaust is another challenge to overcome, perhaps use the exhaust side of another turbocharger bolted to some kind of generator?
