Pete.
- Kent, UK
The advice for unsafe items was always remove the plug... its the only way someone has to do something to put it back into use.
Yes they have to plug it back in.
If you cut the plug off all you're doing is adding a further point of failure by risking having a clueless person try to re-fit the plug using a butter knife as a screwdriver - or even worse, splicing another lead onto the cut-off one with sellotape, or even worse again stripping the wires back and jamming them into the sockets. This is the very reason the law was changed a while back to require all appliances to be sold new with the plug fitted - to prevent badly fitted plugs being an electrical/fire hazard.
If it's a question of liability, someone has tasked the tester to do the work of TESTING. Did the schoolkid or OAP ask for their gear to be tested? No, the school or care home did. So you do your test, isolate and mark faulty equipment and report the findings to them. The responsibility now lies with them to ensure the equipment is not put back into use, not the tester. it's a portable appliance TEST, not a TEST AND DESTROY. You got no right to chop up people's gear.
