JuniorRod88
Junior Fabricator
- Northern Ireland-Ballymoney
Practice Night/Testing
In my previous post i told you that there was a practice day on the 29th of march at @2pm. Well that was moved forward to the 28th @6pm. The day before i got the tires onto the proper wheels and got sorted to go.
While the car was on the trailer i had a wee look in beneath...
Stopped for fuel and then arrived at the track at 6:15pm, it was damp to be fair. after the hotrods were out a few laps it soon dried up. I set all the passenger tire pressure to 30psi and the drivers side to 28psi. That done i when out a run with a 1400 stockrod, a 1600 lightening rod and a couple of other 1200 juniors.
One of the juniors was a novice driver, just starting out in a corsa. The other was the Junior Irish Champion of Ballymena in a phase 2 106. I was quicker than the corsa but still a 4 or 5 lengths a lap slower than the 106. the car had the pull up the straight, but in corners she didn't just sit right. She tried to tail a few time but nothing that wasn't controllable. It wasn't great to be honest, she wouldn't go where you wanted her to on the exit of the corner.
Came in after 9 or 10 laps and checked how the tires where heating. The passenger front had risen to 35psi. Then i realized she was toeing in at the front. Got the lend of a tracking bar and go her to toe out slightly. Took her out again and it was better but still not gripping the way i wanted it to. Came in from that run, refueled and dropped the tires another couple of psi.
Asked dad to take her out a run to see what he thought. The race suit didn't fit him but he has a boiler suit in the van that did. Five minutes later he was on track. He only did about 5 or 6 laps but he though it was it was great, "a tight wee car that pulled well and felt confident when throwing it into the corners, and on the way out she did want i wanted her to". When he told me this i was unsure if we were driving the same car. I waited 20 minutes and took her out again.
There was a dramatic change in how the car felt. It must has been the slight drop in the tire pressure but it definitely felt more planted than before. i was able to brake later, take a tighter line and give her more poke on the way out of the corner. It was just nicer to drive generally. I came in and checked the tire pressures and watched a few boys do a practice. The run was cut short by an accident involving the two other juniors.
On the last run of the night i Went out with a 1.4 nova stock rod, a 1.6 lightening rod vauxhall belmont, a 1.2 corsa junior and a 1.4 corsa stockrod. I was having a great run, braking later and later and getting as close to the wall as possible up the straight and turning in at the right time. I managed to pass the 1.4 nova stock rod, along with the 1.6 belmont lightening rod, but when the 1.4 corsa caught me i decided to go wide on the corner and let him get the inside line. The belmont behind him also got through on the inside. I didn't mind it was only a practice run not a race.
Good nights fun, can't complain. Getting harder front springs shortly, extending a new bottom arm to give more negative camber and caster, fixing a 1.4 distributor and replacing it's vacuum advance unit and fitting it to the car and buying a couple of new tires. Front passenger tire is basically done will put a new one on the back passenger and mover the one from there to the front.
Next meeting is on the 4th of April at ballymena raceway and the next one after that is on the 18th of april, should be good fun. I have a video of dad taking the car a few laps but ill wait before i show it.
Sam
Sam
