octo0072000
- south yorks
i would swap the bottom arm off the saxo if the bush is bad before getting out the
porto power
porto power
I don't know if it's the same for your guys, but the MSA doesn't allow compression bent cages due to the deformation they create.
If that really is you, top left in the photograph, I think you are going to need at least one booster cushion to feel "fitted" in that Kirkey seat, no matter how tight you pull the straps !
I hope you realise I am pulling your leg ! Some good work going on there !
Regards
Are you working under the car with it supported solely by that jack?
