Aston66
- Bournemouth, UK
Hi. I'm measuring the pressure from the tank. I have recently rebuilt the pump unit and the pistons, cylinder bores , valve plates etc appeared to be in surprisingly good condition for a ' cheapo Oriental' machine after 12 years of use.When new, with no internal corrosion, no fatigue from a million pressurisation cycles and no dents etc, it will have been safe at 15 bar if that's what the plate says. 30 years later having been sat half full of water and gunk it's anyone's guess. It may only have a fraction of the material thickness left at the bottom.
If your lucky, if not its goodnight Vienna!
I tested hundreds of PRVs of various types in a previous job and whilst they were often a bit off, especially when old, they were generally fairly accurate. Where are you measuring your pressure from, and where is your PRV situated? On the tank or on a feed/ take off line?
Are you sure it's the PRV letting go that's stopping you reaching the pressure you want and not the compressor failing to reach it or something else letting go. I've seen compressors with multiple PRVs.
As @addjunkie said earlier if your compressors old and knackered it may not ever get to its original design pressure, let alone more.
If your finding numerous PRVs are all low then I'd suspect your gauges, or where your actually measuring your pressures from to be the issue. Get yourself a bucket pump and test them against a known good gauge.
The check valve and unloader valve also function correctly.
The pressure switch unloader valve works as it should too.
It does begin to look like all my gages are Knackered. It's the only conclusion that makes any sense, I shall buy another Guage and see what it reads .
I would not like to run this compressor over it's safe working pressure, Wich is obviously why I'm so concerned about the PRV , in the case that the switch does fail. Usually I keep an eye on it any way, when I'm using it, to be frank, I don't trust it since it dropped a Conrod. It gets drained down every time I'm finished with it and I don't think I have quite managed to exceed it's duty cycle yet.
I have been led to believe that the receiver, should accommodate a PRV of 10% of more than safe working pressure. That the 15 Bar figure is a pressure test figure with water and that the figure at which the receiver breaches is probably up to two times that figure ???
I've read that amongst posts on this very forum.
However I certainly don't want to try to achieve anything over 145 psi.
I guess that I should take heed of the advice given to me in this thread, and stop ' pushing ' the capabilities of this Knackered old piece of Asian manufactured junk.
