Voipio I could use your help a little concerningWhat tool do you use to remove the old seal? If I remember correctly, the o-ring seal for the gas tight connection is buried in the cylinder connector, so you basically get a new one with each cylinder.
They used seals that are incompatible with the gas they are designed for?
There must be a use-by date.
Jack
The seal for the brass stinger sticking down is indeed down in the top of the bottle but the seal that could be the culprit is the rubber flat washer (sometimes cork) that remains with the torch head and unless it has been replaced before it is the same age as your torch. They go bad quite often.They used seals that are incompatible with the gas they are designed for?
Jack
Jack
for the o rings watch
there is one between the bottle and the torch head
be warned ive known mapp gas bottles to leak after unscrewing them as ive used them for a very long time
its no fun getting to a job to find that your gas bottle has leaked and you have no gas to start the job
but my usage is often, only time it dosnt get used is when its holiday time 2-3 weeks or not used over the weekend so im not a casual user
ive taken the mickey out of the mechanics using a plumbers blow lamp as there a casual user whilst the rest are diy users
whilst both me and kayos can state that
your input on a question the Weller soldering iron
