RaceDiagnostics
- Broughty Ferry
On to the steering box, should be an easy half day job for a first time, or an hour second time round. So this is how it went.....
Pitman shaft driven out.
That's a lot of seals to go in.
Removing the front cover of the steering shaft showed this, a sheared bolt, someone has obviously been in here before me and did a bad job.
Worm and piston removed.
First I tried removing it with a centre punch, this has never worked for me in the past but I always give it a try before welding on a nut.
Incredibly it was loose and came out.
Next this circlip.....
.... and removed this cap.
That's a lot of seals.
Pitman arm seals and O rings replaced.
Next on to this nut.
I held the nut in a vice and tried two different chain wrenches. both bent.
Then a long lever but the nut was slipping in the vice.
The solution was to drill a hole in a bar for the shaft then weld the bar to the nut.
Two long levers.
And its off.
Hopefully tomorrow will go a bit smother.
Two long levers.
And its off.
at least you sussed it ..before going any further
..well done for that and well done for doing the job before your wondering why it smokes so much on start up
