Parm
Respect The Sound System
- Towcester
http://www.iorw.org/article_june1001.html
http://www.itw-welding.com/media/Pdf/Literature_download/RailWelding.pdf
http://www.tatasteeleurope.com/en/products-and-services/long/rail/welding
Just google "weld Repair Rails" and there are loads of articles
We in the UK may have stopped but we definitely used to repair them back in the day. I was at the inaugral IoRW meeting possibly 12 years ago, maybe more, when it was discussed for the first time. I recall the Railways Expert on welding was a Geologist who had the stock answer "I dont know Im a geologist". After a while I suggested they may be best advised to employ a Metallurgist..
Most of the consumable manufacturers make consumables specifically for rail weld repair.
and the waggon being designed does grind but it also welds and NDTs the finished joint...........maybe its intended for Europe of elsewhere..I dont know
I bow to your superior knowledge but I think the key is in Joint, all tracks these days are joined end to end by thermic welding so the ride is smooth (no bumpety bump). But I'm not aware of any track being built up with welding and reprofiled. Worn track is simply replaced if it can't be ground back to spec.
This new waggon I suspect is as a result of some of the work I've being doing over the last few years where we found the risk of exposure to HAVS was unacceptably high and a huge number of industrial claims being made
